So the other day my 03 kx125 had a problem. I dropped it very easily on the kickstarter side after realizing I couldnt make a climb I was attempting. When I wheeled it to the bottom of the hill, it started right up, but would go into 1st, then up to neutral, but nothing higher. I'm assuming its the shift fork, but I am undecided whether or not I should attempt the fix by myself, (I work as a small engine mechanic, but never messed with bike trannys) or if I should just tear it apart and send it to a pro. While the bike is apart Im going to put in new clutch plates, and rings. Does anybody know of a good transmission mechanic in NY. Specifically in the general area of Middletown NY? I would hate to send it to a dealer, because most of the local dealers arent very good at all. Any input would be great! Thanks in advance
