4wheel thunder has tested this and so has rdz racing i believe, on some bikes/quads it can equal up to as much as 3 hp at the rear wheels due to drag resistance and weight ,planet sand had some posts concerning this testing done a while back if i remember right .of coarse that gain will vary depending on the bike but for the most part you want an non oring for drag racing because every little bit helps ,a tenth of a second is huge in a short drag race and often they are won by just a couple of inches ,will it make a noticable difference on a small motor like a 125 in a dirtbike frame driving a single lightweight wheel ?probably not something your going to feel ,your probably best off with an Oring style if you ride in a more unforgiving environment as they generally last longer and stay cleaner in mud/dirt conditions because of the seals on the links,with that in mind it could be said a clean lubed Oring chain thats working properly would surely be better than a dry kinked up corroded nonOring chain type
