The carb is a Kehin PJ. As a side note, I am also running a smaller version of this carb on my 85 cr125 with the same size pilot and no problems running or idling with 62 pilot. Is there something in that carb that I could be missing that would cause it to run rich? Something worn out? Also, it is possible the rh seal is leaking but I have replaced it along with a new collar for it to seal against.
The piston wasn't blown up when the bike came in my shop, just scarred up with stuck rings, but another one could have blown up in the past and damaged the cases. I'm almost sure it's not coolant in the crank case. It's a clear goldish color and I'm not loosing or pushing any water out of the radiators. Anyway, please don't take me wrong all the suggestions are appreciated. I'm looking at about 3 possible causes, 1. oil coming in thru rh seal 2. oil coming in somehow (cracked, damaged cased, damaged gasket) thru trans case into crank case 3. jetting too rich ( pilot jet).
I can try to rig up a leak tester to verify 1 and 2 and try a smaller pilot for #3.
One more bit of info. Once I get the bike pulled off and running, it won't idle so I have to keep reving it. It smokes bad and doesn't rev cleanly. It 4 strokes. When I take off in first it won't rev much, it just four strokes, but it keeps getting better until I hit 3rd or 4th gear then it clears up and revs, but still smokes bad. I can keep the revs up and it doesn't run too bad. It will spin the tire, which is about 85%, in all gears up and down my gravel drive, but as soon as I let the revs come down it loads up again and starts 4 stroking. Thanks again for the help.
