I hear a lot of talk about Nology in these forums,so I ordered the profire coil and a set of nology hotwires,any suggestions on mounting the coil and the best place to ground the hotwires.2001 Banshee
SMKMUPBANSHEE said:Where Can I Get One At?
Smokin'Gun said:The coil makes a difference but that stupid 35$ a wire plug wire is overpriced to say the least. All my racing sleds have NGK racing wires and the spark is just as hot and consistant as with the nologys and theyre 15$ cheaper. I read an entire article about comparing the NGK race wires to the nology wires and the results were that the nologys werent much better than NGKS.
370banshee said:well you can;t use the NGK wire on a nology.... beinge tha the nology has a seperate wire.. and the ngk is a one piece coil and wire....
higher coil output is always a good thing...
