I checked my timing today and it's at +4..and I run BR8es plugs which to me is darker brown color..tried to upload pics but won't let me
I checked my timing today and it's at +4..and I run BR8es plugs which to me is darker brown color..tried to upload pics but won't let meNeed to know more about your setup to tell you where to set timing. Typically +4* advanced is OK. Id set it at 0 to be safe. Run an 8 series plug.
It needs rebuilt bud.I checked my timing today and it's at +4..and I run BR8es plugs which to me is darker brown color..tried to upload pics but won't let me
how does that make sense?? It runs very strong..tons of low and top end power..starts up first to second kick all the time no choke..It needs rebuilt bud.
The cylinder cranking compression differs by 15-20%. Which side is compression low?Right side is 124..and left is 105 to 110..
I've rode on a quad with a tired motor and yes there's a difference in compression on mine like I said before it runs strong and again starts on the first or second kick cold all the timeThe cylinder cranking compression differs by 15-20%. Which side is compression low?
If my engine isn't ported and polished like the previous owner told me because personally I don't know if it is..is +4 timing to high for what I know I have done to it..like pro circuit exhaust, vforce 4 reeds and cage, airbox no lid, tor's deletedI checked my timing today and it's at +4..and I run BR8es plugs which to me is darker brown color..tried to upload pics but won't let me
With those mods deff gonna need to up your main jetting, running stock size jetting??If my engine isn't ported and polished like the previous owner told me because personally I don't know if it is..is +4 timing to high for what I know I have done to it..like pro circuit exhaust, vforce 4 reeds and cage, airbox no lid, tor's deleted
Idk what the jetting isWith those mods deff gonna need to up your main jetting, running stock size jetting??
In your carb you'll have the pilot jet, and your main jet. Little brass nozzles you screw out. The main jet is usually the bigger one. Pull your main jet out, clean it up, and it should have a number on it. Buy a main jet kit, whatever number your original has, go a bit higher and try that. Might take some experimenting with diff sizes to find the right one for your quad.Idk what the jetting is
What oil gas ratio are you currently running? Not enough two stroke oil will DEFF cause issues as well.Idk what the jetting is
With these mods with the port and polished work what you my main should be?? And what should it be with port an polish work..because again idk how true that isIn your carb you'll have the pilot jet, and your main jet. Little brass nozzles you screw out. The main jet is usually the bigger one. Pull your main jet out, clean it up, and it should have a number on it. Buy a main jet kit, whatever number your original has, go a bit higher and try that. Might take some experimenting with diff sizes to find the right one for your quad.
First ya gotta know what size your currently running. There's no one size fits all in the carb jets. Gotta pull car apart. See what's currently in there.With these mods with the port and polished work what you my main should be?? And what should it be with port an polish work..because again idk how true that is
280 Main jet would be a good starting point.With these mods with the port and polished work what you my main should be?? And what should it be with port an polish work..because again idk how true that is
As you're sitting on the bike it will be there left sideDo this to confirm main jet sizing: http://kawatriple.com/carb/plugchop.htm
There is a reason compression is so different. Bike will never run as good as it can with compression that much different, its also hard on the engine. Which side is low?
you could have a look around the cylinder and intake boot on that side for a small air leak or leaky stator side crank seal. do the revs hang at all?As you're sitting on the bike it will be there left side
Ended up being my water pump propeller was completely shot..you could have a look around the cylinder and intake boot on that side for a small air leak or leaky stator side crank seal. do the revs hang at all?
