Thanks for the help. I Decided to swap the 39mm carb for a 35mm. It solved alot of my problems. I just started a new project with this blaster I picked up for $300. Bought some things like Vitos big bore kit, Vitos +3mm stroker crank, FTZ alcohol carb, aftermarket head with compression domes, a pipe and things like that. This is my first 2-stroke build in a while so I'm just starting off with the motor and will work my way from there.
