1 - 7 of 7 Posts
I am having a problem jetting my esr 310 cylinder. It is stock porting, full pro circuit system, no airbox lid, vforce 3 reeds, and has a stock 34mm carb. The problem is it will be idling, then it would shut off. the pilot jet is 42. Main jet is 170. Needle is on fourth clip position. Thank you for all your help.
You need atleast a 38mm carb on that
^^ Agreed. You need a larger carb. But I don't think, that is your initial problem. Check your float level. Clean the pilot jet. Air mixture screw should be 2-3 turns out. Let us know.
Discussion Starter · #4 ·
i didn't check my float height yet. However, whenever i turn the gas off while it is running, it begins to idle how i would want it to. Does that have something to do with the float height?
It could.
I have 2 carbs (lectrons of course) 34 and 38. The 34 runs fine on the 310. I prefer that carb in a woods setting because of fuel economy. I run the 38 at races.
Discussion Starter · #6 ·
i leaned out my float height and it is idling much better. I also brought my pilot up to a 50. Thank you for your help. I will get a 38mm Carb in the future.
1 - 7 of 7 Posts
