Ok have an issue with water. I removed the parking break, carb tops, and the Tors controler. I wrapped all the plug ends with electrical tape and for some reason as soon as I go through water the banshee kicks in a rev limiter similar to the TORS. If I am spraying it down with the pressure washer it does not do it but going through puddles it kills the rev. Once the bike dries out it is fine. I am going to try spraying water at all the connectors while it runs to see if any of them kill it out. Any thoughts?? I am also going to put water proof silicon in all the connector ends to see how that does
