1 - 20 of 32 Posts
It's really simple and doesn't take long at all. Added a few pics too.
Pointing at the TORS brain with a screw driver..
Sits right behind the hood, Unplug it from the harness.
Throttle electrical is also removed. Housing is removed to access screws holding it in place.
Chase the line down behind the hood and unplug from harness.
Ohh.. I used black RTV Gasket maker to fill the hole & keep debris out.
Same thing with the carb, unplug the head from the harness.
And don't leave the plugs on there. You don't need them anymore, chase those wires all the way down & strip from harness
Since you're throwing out the carb cap, tors head and throttle cable you'll need to replace with something like this.
Need a new throttle cable, carb cap with adjuster on top, idle screw, #6 drill bit & 6mm X .75mm tap
[drill bit & tap not shown in pics] & ended up with different cap.
Discussion Starter #2
Idle screw boss must be filed flush for jamb nut to hold screw nice and tight.
[I actually used a cutting wheel]
Here you see the carb cap replacement with idle screw in place, throttle cable is installed so I'm good to go.
I flipped the carb around, you can see the black vacume plug where oil injection line used to be.
1 OUT OF 3 AINT BAD
Yes great info I always wanted to ask what tors were and now I do.
Yes great info I always wanted to ask what tors were and now I dont.
Throttle Overide System.. Made to shut down it motor should carb get stuck wide open.
It's a horrible Yamaha system that fails.
1 OUT OF 3 AINT BAD
thanks climb. (The dont was supposed to be a do.)
you dont know how long ive been looking for pics on how to do this. but dont you have to jump the wires back? or is that just for disengaging the tors unit without actually taking it completely off. i might do that for the time being. util i can ge a vitos kit or something
Discussion Starter #9
I'm taking the whole thing off and stripping the plugs off the harness.
Old School but still Cool
Friends don't let friends us TORS, and we are all friends here. So don't use TORS please.
The tors doesnt work anyway. ask suggy.when she first got brand new blasty we were in the mud throttle stuck wide open in the tight trails...off she went over berm in to bushes..lol..good diy!!
Discussion Starter #13
^^ Yo, same crap happened to us at Dumont Dunes in the middle of the desert with no one around.
Moon dissapeared & lost my sense of direction...
Discussion Starter #15
when did that happen, Climb?
Last year at the DC gathering.
We took off for a ride came back hours later.
Rode to up to some duner's camp asking for help.
Welcomed us in their bus for a few drinks then helped us haul it back to camp.
Showed up at camp with a bunch of new friends lol..
Play Hard Get Dirty.
LMAO!! wait...I thought you were saying something happened with getting thrown off the bike or TORS removal so I got confused.
Discussion Starter #17
You're getting Sugar/Nelson's story mixed up with Sandbox/Climb's story. :Laugh6:
My experience with the yami T.O.R.S has been that it never really worked as they intended and that it tends to fail at the worst possible time. Either leaving you stranded in BFE or causing a wreck.
I have my old blaster right now, tryin to fix it... somethins up with the carb, maybe i'll have to take off the tors or somethin. check out my thread.
1 - 20 of 32 Posts
