1 - 5 of 5 Posts
I have to look at the water pump soon in my Banshee and I am looking at this Spectro SX Clutch Saver oil. Has anyone ever used it? Doesn't matter if it is in a Banshee or not. I got my Shee at the end of 2013 and I changed the oil last summer and replaced it with Valvoline ATV 10W-40. It works fine but seems like there is a little drag to it and just wanna see if anyone is using this. I use their Golden Spectro mix for my Banshee and DT 125 and they love it so I just want to try this out. Thanks.
I'm not familiar with it.
I generally use ATF in my 2 stroke trans and have good results at a fraction of the price of some of these specialty fluids.
You definitely Do-Not want to use ATF in a 4-stroke as oil in the transmission is used to lubricate the piston and crankshaft, etc. !
Not familiar with it either. Always had good luck with regular 10W 30 motor oil. Just about any oil will cause drag in cold temps till it warms up to operating temperature.
1 - 5 of 5 Posts
