1 - 5 of 5 Posts
I had just rebuilt the whole entire water pump on my trx250r. Nothing was coming out if the weep hole until i started it. White smoke was coming out of the weep hole. It did not have an effect on the engine running, but i do not think this is normal. Thank you for all help.
I have never heard of this happening.
Discussion Starter · #4 ·
Yeah but i checked the radiator and it was low. I'm guessing the coolant is burning? I think the new kit I got had problems with it
Never seen smoke come out of the weep hole. It could be low enough on coolant to start steaming. It will drip coolant to indicate something isn't right with the mechanical seal. The only way coolant will burn is a bad head seal or cracked cylinder. White smoke then will come out of the exhaust. Fill the radiator and run it. Keep an eye on the weep hole.
1 - 5 of 5 Posts
