21 - 36 of 36 Posts
· Registered
If your talking about the lobes of the crank having play, no thats not good lol. There should be very little rod play as well, The trx dosent have thrust washers at the piston like the lt's, they are on the big end.
· 1986 Honda TRX 250r
Discussion Starter · #23 ·
im talking about the crank assembly inside of the cases. the crank is moving side to side on the MAIN CRANK CASE BEARINGS. Thanks
· Registered
That is not good at all. How much play is there? Is this a old crank? Never delt with hot rod bearings but I cant see them being a different size than oem.
Discussion Starter · #26 ·
how do i get it fixed?!?!?! haha thats what i ve been asking all along. anyway. i took the crank out and noticed that the crank bearing is deeper in the case on the left case. So pressed it back out a little and it fixed the problem. I am NEVER buying used cases EVER again. theres always something.
· Registered
Maybe those bearings are different than oem and must be used with a hot rods crank. I doubt just pressing the bearing to where you need it to be will solve the problem. I'd just buy oem bearings anyways as I dont trust anything else for mains
Discussion Starter · #29 ·
I have no clue what i should do. Maybe buy thicker bearings or something. If not, screw it, im throwin it together. Its not much movement. but my hotrods crank fit WAY tighter. My bearings dont fit very tight on the crank compared to the hotrods. Do you guys have to press your bearings on your cranks or do they just slide on?
· Registered
I'd measure your bearings and go to the dealership and measure an oem bearing. The bearings should not just slide on either. I have to use a crank puller to get the the crank in the bearing on mine. I also wouldnt just throw it together till you got this figured out. If your crank walks at high rpm its gonna cost you alot more than just a set of bearings or a new crank.
Discussion Starter · #31 · (Edited)
man. this is causing all sorts of problems. im going to have to buy a crank then......... because mine is worn. i guess.. whats weird is where the seal runs on the flywheel side, where the bearing does NOT run, it still slides on easily. Maybe when i put them on my hotrods crank it stretched the id out a little on the bearing or something./\
Discussion Starter · #32 · (Edited)
well i think i have found a lupole. (spelling) im going to get some shims from the autparts store and shim it so there is no movement. then im going to get some loctite and put that on the crank races and bearing races just to make sure that doesnt want to spin. Unless tughill283 wants to sell his crank to me for cheap.
· Registered
to be honest with ya im kinda uneasy about selling that crank to a member on here,i dont want you to throw it all together and have a crank i sold you fall apart.the loctite is a good idea and on my crank the bearings fit tighter in the case than on the crank.you can almost slide the bearings on the crank with hand strength.
· Registered
Man save your cash and do it right. Either buy a hotrods crank or, your best bet, buy some oem bearings. If you have a bad failure caused by those bearings with that crank its gonna cost you alot more than the 50bucks or so for oem bearings. Thats a fact
Discussion Starter · #36 ·
If your talking about the crankshaft in the engine cases. Then no. little to none. If there is your main bearings are likely shot and you will soon find up and down play as well. I find the main bearings dont actually last as long as one might think. ( compared to wheel bearings on a trailer, wheel bearings on your pickup etc) My engine runes just fine has great compression but the main bearings are giving it up. maybe its just my specific engine but im finding up and down play at the flywheel. it still runs but is in desperate need of a rebuild because of that reason. However side to side play in the ROD. on the crankshaft is normal. up and down play in anything in the rotating assembly. wrist pin, upper and lower rod bearings, or the main bearings is going to cause you major trouble shortly if you dont correct it.
21 - 36 of 36 Posts
