1 - 9 of 9 Posts
Hey all, the shifter on my shee went total limp. It still shifts but will not spring back to home position. Does any one have any ideas? Im sure if i keep riding like this im asking for problems. thanks.
You'll need to pull the clutch cover and look at the shifter spring/shift start mechanism. Probably a broken part but the fix is most likely an easy access fix. All the shifter goodies are in the clutch cover area, probably no need to pull the engine or split the case.
Discussion Starter · #6 ·
Ok i pulled it all off and the springs in good shape but im thinkin there should be a stud or somthing to hold it in place cant tell by lookin at this manual
pics of what your seeing bro will help alot!
1 - 9 of 9 Posts
