Well, with that picture, your kind of looking at it. The water runs through the rotax cylinder in its original configuration. When I had a spacer plate cut I just made sure the water jackets were not cut through it, so it just doesn't circulate down, it'll go under and around the exhaust port, but it will flow in through the new spigot I welded on the head at the exhaust side of it, go down into the cylinder, and then get pumped out the back elbow right above the intake. It basically stops at the bottom of the cylinder when it meets the spacer plate. Probably not exactly the most efficient way to go about doing this, but should be good enough.
