1 - 4 of 4 Posts
10X5 3.0 + 2.0
Obviously the 10x5 is the size, but what is the 3.0 +2.0? I assume one is a backspacing? Thanks-Dan
Free 4-stroke beatdowns!
3.0 + 2.0 is stock offset for the majority of atvs. 3" to the inside and 2" to the outside. If you want a narrower track, you would buy 4.0 + 1.0. You can get them 2.0 + 3.0 to make it a litle wider also.
Moved and Pinned thread in our Rim subforum. Thanks!
1986 Honda TRX 250r
yes you can widen your atv with different "dish" rims, but the wider you the more you will feel in the handle bars, if you are running a 1-4 offset, when you hit a rock it will jerk your handle bars slightly, when you have a 4-1 offset when you hit that same rock, it will jar you much more easily because of the leverage ratios. Its a trade off but ill let you decide what you want.
1 - 4 of 4 Posts
