1 - 4 of 4 Posts
is ktm known for a weak spring or somthing in the rad cap cause i was riding stoped and looked down the anti freeze was coming out of the overflow tube? just wondering if its a typical problem with them and did they get any better on the newer models, cause i might swap them?
Discussion Starter · #3 ·
i think i found a solution to my own problem, ktm cycle hut sells a c.r.t (coolent recovery tank) for most models. just puting that out there if any one is having the same problem
if you fill up the radiator coolant will come out the overflow when the engine gets hot.it will keep doing it till the level goes down to its happy spot then it wont overflow again unless you get the motor really hot.i wouldnt want a overflow tank on a bike and theres no need for it imo.
1 - 4 of 4 Posts
