A short while ago I burned a whole thru the piston of my Blaster. The cylinder was scored and needed to be bored. The bore on the cylinder was already at a 68mm and they only make one more size larger than that but I needed to go two sizes up to clean the wall.
So I've been thinking rather than try to find a new cylinder or used one off of ebay or a junk yard(that's probably been to large already) or even have it resleeved, I might just go with a Big Bore Kit. Then I got to reading previous threads and there is alot of suggestions for strokers over big bores. But from all the threads I've read I haven't heard any downfalls to strokers or big bores, Other than the piston for Vito's kit is Junk and go buy a Wiseco.
Anyway I guess my questions are:
1. Has anyone had any problems with Big Bores in general, and specifally with over heating?
2. Same As question #1 with Strokers?
3. Can you go big Bore and stroker?
4. Ultimately, I Have to top end for my blaster. Can anyone help with some ideas and insight?
