hello from NJ. I've been riding for over 35 years now, and with a 15 y/o, I thought we buy a nice toy for him. We found a nice working damn near original 1978 FL250 Odyssey. We went to Mass to pick it up. Ran it around the yard and up on the trailer. One the way home in one of those NASTY snowstorms, we had to stop every 50 miles or so and knock off the ice.
I prepped it for storage and it spent the long winter in a portable garage dry an out of the elements.It needed major cosmetic work....new cage....fenders...seat was literally duct ape wrapped around the frame. But it ran.
Now I've re-assembled it with a new lined gas tank, professionally shop re built carb and all new wiring and switches. The PO put new switches in and left all the old wiring there, leaving me with a snake nest behind the seat.
The pull starter and bottom off the flywheel housing showed evidence of water infiltration because there was a dent in the flange of the pull starter letting in water. The flywheel needed to be scotch brited but the stator and coils were not damaged that I could see.
Everything rings out on the meter fine, and the ignition coil rings right on the money But I get no spark. All the wiring is correct, and everything I've read about to check, checks out. Flywheel key...EVERYTHNG.
What am I missing?
What am I missing?
