1 - 1 of 1 Posts
A top end was done on my 2000 cr250. Now the power valves do not operate. I took the cover off and I am unable to rotate the valve drive shaft when gripped with a pliers. I am thinking that the valve drive shaft was mis-aligned with the pinion shaft when I replaced the cylinder. Am I able to correct this without removing the cylinder?
thank you
Gil
1 - 1 of 1 Posts
