Got the 86 SCREAMING !! I miss 6th gear buy it still rips in fifth . Put a Barnett Dirt Digger Kit in it the other day and she is screaming ! Still need to get the carb figured out , get some plastics , solder and shrink wrap some wiring and fix some of the last owners "rattle can " paint work but its coming along ! I guess I should just rip the carb apart and rebuild it the Idle screw is bottomed out and I need to twist out the cable adjuster at the twist grip to keep it running ?? and it still floods gas into the cylinder and pipe when its parked with the gas on so I guess I need to adjust the float or replace the seat if its not sealing up ?? It also randomly feels like its running out of gas at full throttle (again im guessing gunk in the carb) I only did a quicky clean up never really pulled it apart and went through it completely .. still need to score some plastics if anyone has a set!
