You might hold a match over the plug hole when you kick it over to double check whether it’s gas or not.
You also might try to retorque the head studs to see if you have any stripped threads.
Suzuki cylinders have a rather robust iron sleeve, I’ve never seen one with a crack which would cause a coolant leak
Somebody else may have some other ideas.
