Interesting! The metal spring loaded valve is a double edge sword in my eyes as you cant get too stiff a spring, or it will resist opening and restrict flow, too soft and it wont close until a reversion occurs. Kind of the same thing with a typical reed valve. I get a kick out of discussing this kind of stuff so dont take my comments as negative! One thing i did as a kid was grab the air compressor blow gun and take a reed valve and try to blow air though it as if the engine were, but without the quick gulps an engine creates. What I found was interesting was how little the reed valve had to be open to flow a LOT of air. the ability of a typical reed valve to flow a lot of air without the petals being open much is what makes them shine i assume. lot of surface area like a pleated air filter. Why moto tassinari had designed he v force reed valve with two set of reed petals instead of the conventional single pair im assuming. More surface area. Great discussion here though im glad you posted this. But you never explained what engine this new reed valve was designed for? maybe were not on the same page!
