2002 Yamaha BLASTER
I have a 2002 Yamaha blaster and when I kick started it started it rotates twice and then bounces bounces backwards it won't rotate forward 3 times or more. What could be the problem?
2002 Yamaha BLASTER
Discussion Starter · #2 ·
Ok update I found the problem. It was a c clip on the main crank sprocket had fallen off. So what was happening was the gear would move back and fourth when you would try to kick start it witch in return would let the motor rotate backwards. I put a new clip on it and it stopped the motor from being able to go backwards.
