Hi guys first post so sorry if i forget stuff
Fixin my brothers lt250r he picked up cheap
Transmission was full of gunk and pretty much all seized.
I cleaned up everything and lubricated everything well then i reassembled.
When i tried to test if it would engage into all its gears, as it should, i found that it would only go into 1st ,N , 2nd and 3rd but no 4th 5th or 6th.
I dont understand because before i put the cases back together the shift drum would click into each position correctly but now that the cases are together it will only go as far as 3rd.
Any help is really appreciated
Thanks
Ray
Discussion Starter · #3 ·
Thanks
I figured it out
The engine needs to be in motion for each gear to engage so unless you turn the crank or drive shaft they cant engage haha :Dope:
