I recently bought an 86 lt250r and decided to restore it so I bought a carb rebuild kit and I got all the jets put in but I can’t get the throttle needle out of the slide piece am I missing something that holds it in or is it actually just stuck and needs working with
35594
35595
You have to remove that plastic piece down in there.With the spring pulled up as you have in the picture turn the side upside down and it should fall out.With that out of the way you can then slide the cable out of the slot......If the plastic piece is stuck can spray it with penetrating oil or use compressed air .
