i have a 1992 ktm250exc that is leaking oil out of the right side cover.can i take this side cover off and replace the gasket without messing stuff up(parts falling out etc...)????also i believe oil is leaking out of the seal around the shifter too where it goes into the engine.can this be replaced from the outside or does the case have to be split????thanks for any input and help
