· Registered
Bit of spluttering and carry on
idles fine, will idle all day no problem. 1/8-1/4 will bog out, coughing and spluttering until it comes to a stop and fouls the plug after about 30seconds
eg. If i start the bike and ride off down my street, giving courtesy to my neighbours :angry5: i need to be using this range (1/8-1/4), however i have to say fukit :finger4::finger4: and go WOT down the street otherwise the plug will foul. Once the bike is hot there are no issues
im using the stock setup Pj42, Mj172, noz H 1st clip. new boyesen power reeds
· Super Moderator
that happens when there is too much clearance between the needle and its jet. The needle jet gets wallowed out due to needle vibration. So you need to replace it and if the problem persists then buy a needle that is wider to decrease the clearance.
