· Registered
I’m stumped. I recently replaced the cylinder and piston on my ole reliable ‘06 husqvarna and now it won’t start. I’ve checked for kill switch shorts, Coil-flywheel gap, carb is new, compression is good. I put a tiny bit of 2 stroke oil in the cylinder and forgot to take the plug out so maybe the oil fouled it out when I pulled on it? I’m not sure but I doubt it. I’m not ready to retire it just yet
· Registered
Check the spark plug. If you put that oil in it that could’ve fouled the plug. Also sounds like you may need to adjust your new carb.
