Ok here are some directions I hope they help.
Once you go into the Photo Section. Up in the Right hand corner there will be your menu bar. If it has Login as one of your choices then that means that you need to login to the photo section. This will be the same username and Password as the Forums.
Once you are logged in you will see a Option in the upper right hand corner menu for Upload Photo. Click there. Then all you need to do is fill in the information and browse to where the photo is on your hard drive. and select it. Then hit Submit at the bottom.
Hope this helps if you still don't get it let me know where your getting stuck so I can give you more detailed directions.
Thanks
