1 - 12 of 12 Posts
just bypass as much shit as possible
Get a automotive electrical test kit from Wally world and start checking the wires w/the scematic. It should be fairly basic wireing.
If the problem is a bad switch, I have a nice ignition with key and kill switch. I'll make you a good deal. PM me if interested.
well it appears that everything is hooked up.. did something come unplugged??? broken wire?? if so what wire would it be where both the kill switch and the key do not work...
well if the mag on a bike works the same as on a plane you need to ground it to shut if off so if your ground is bad it wont shut off.
1985-1986 Lt250r Genius
All that switch does is ground the plug wire to the frame. You can just rewire those pretty easy. I would reccomend bypassing that switch & getting a tether...
cool i was right.
1 - 12 of 12 Posts
