Hello Gurus,
Cracked open an old Suzuki sled engine and thought I had found the problem with it. Overheated crank pins as visible here
Then a closer look showed no such discoloration on the needles. ¨Could´ve rubbed off¨ I thought.
Next, once the crank was out, a better look overall showed not only the exact same discoloration around both crank pins but none on the pins themselves.
Furthermore, the heat coloration extends around the actual shaft, on both ends, and only there. The rest of the webs and shafts are fine.
So, looks like the holes for the pins are heated for assembly, but that leaves out the coloring around the shaft.
So, are the shafts ground to final size and overheated in the process? The discoloration from around the pins appears to have taken place after the one around the shaft.
Bearings from either side show no heating marks at all.
I had never seen this before. Can someone explain, please?
