hey i have a 91 lt250r....im looking to get a little more out of 1-3 gears. first gear is like point 3 seconds long and doesnt give out and power. what size sprockets should i use...id like to use 13 teeth in the front. i think that size helps clear the bumper on the swingarm so it doesnt wear as quick...i could be wrong though. id like to go up 2 teeth bc i think this will put 1st and 2nd a little longer. i have a dg pipe and silencer, prodesign reed spacer, boysen reeds(if i get new reeds and a cage will it fit through the reed spacer??) k&n filter and outer wear and for tires 18's on the back and 19's on the front.
will i beat a z400 with a slip-on? and does anyone know anything about predators? my freind was swearing his predator would be my quad. he said i wont be able to keep up. i know his quad had nothing on my cannondale. im pretty sure when i get my lrd pipe ill smoke that ass.let me know if anyone is around shaw air force base in south carolina so you can help me show my 4 stroke loving freinds how much better a stokre is.2 strokes rule !!!
john graham
shaw air force base, south carolina
john graham
