121 - 140 of 140 Posts
Discussion Starter #122
Discussion Starter #123
Been forrrrrrrrrever, but I'm finally back on this engine install. Brand new o-rings through the entire pvalve, but still got that leak at the #10 o-ring. GRRRRR! Old #10 o-ring looked fine with no cut, too. Time to take it apart AGAIN. There must be a void or something on the pvalve bore.
Discussion Starter #124
Ok...so.I took the end linkage off (duh) and confirmed the leak is at the double o-ring.
I don't remember, but is the pvalve shaft supposed to be able to push in/out a tiny bit? This one will move about 1-2mm. With it pulled out, the leak is much slower. But push it in and she gasps. I may need to check the schematic and maybe locate some slightly tighter o-rings (?).
Discussion Starter #125
Replacement power valve assembly on its way. Snagged one off eBay on a best offer of $50 + $7 ship. New valve body alone is $107 (dealer price w/ discount), so I'm hoping this other valve is in better shape! Part will be here by Tues.
Discussion Starter #126 (Edited)
Replacement powervalve, new Honda base gasket (other one has a tear), and new small front cylinder stud (near p-valve window, current one is stripped) arrived. Also bought a pair of master cylinder cap screws to replace the rusty ones. Hoping to get things turned around this weekend. Would be a fun Happy-Fathers-Day gift to me to have this thing fiiiiiiiiiiiiiiiiiiiiiiinally running. =)
I've found pretty much whenever I buy a used LT500R cylinder, I should just replace ALL the studs, buy new hole locator dowels, but new OEM base gasket, pvalve seals, and plan on at least (2) heli-coils. These things have been around for a while and only a few people are gentle with them. No matter how good something looks, it will also have a lot of secrets!
That's the problem with power valves, how do you tell exactly where the air (leak) is coming from?
Did an older RM that drove me crazy. Once I got PV cover and vent sealed, still wouldn't know if it had a cases or seal leaks .
Runs fine, didn't change any jets, doesn't smoke (excessively, lol, it's a 2smoker)
Discussion Starter #128 (Edited)
This air leak was 100% between the valve shaft and the double o-rings. That's where the bubbles were coming from.
I really don't know if a leak here can/will even muck up your fuel/air and your jetting. I just prefer -0- leaks.
Had to tap the threads in the pvalve position-lock bolt hole (the one that points up on the bottom of the cylinder) -- it was stripped so bad the stock bolt actually fell out. Its now M8 thread. I need to turn down an M8 bolt with a nub end. Yet another piece of evidence this jug once had a rough life.
Discussion Starter #129
Well the new pvalve set screw/bolt is done. I lied, its M7 (not M8). I took a 25mm long hex bolt, cut it to length with the metabo, filed with the metabo disc and a hand-file, chased threads with a die, and after a few iterations of filing it fits perfect. Test fit the jug on the lower end, and there are no clearance issues with the slightly larger hex head.
New factory pvalve stud in the jug. Old one was a bit chewed. Also have a new factory nut to match.
Also got the old front master cyl screws out and new ones in (with anti-seize). Topped off my fluid as well.
If kids are in bed on time tonight, I'm planning to work some late night hours in the shop and get the top end back together. I'm using some brush-on copper gasket tack on both sides of the new OEM base gasket. So I'll get the jug on with bolts/nuts hand-tight tonight, and then will torque-to-spec in the morning, followed by a leakdown check tomorrow evening.
Discussion Starter #130
Anyone know what the #8 o-rings are made of? Its green, so I'm thinking its HNBR or maybe even Viton. For the price...I'm guessing HNBR (Viton is never cheap). I ask because I wonder if I can soak them in some oil that's doped with some seal swell (or methanol) to get them to ever-so-slightly swell up. Only looking for like 5-10% swell.
Discussion Starter #131
Replacement pvalve installed, new gasket installed, top end installed. Even without the base bolts/nuts torqued to spec, the leakdown test proved the crankcase would only drop roughly 0.3psi over 1min (drop from 8psi to ~7.7psi). This time when the crankcase was above 5psi, the o-rings somehow "seated". Up until ~5psi the double-orings were still leaking air. And then when I was over 5psi, its like the seated and stop leaking air. From a leakdown test perspective, as it sits I would ride it (obviously would torque everything down first). But I'll check the base gasket, seals, head gasket, head nuts, etc.
Also noticed the small M6x1.0 stud that goes through the pvalve window...it needs to be about 1-2mm longer. I have a new factory stud and new factory nut. The nut is a lock-nut, but the there aren't enough threads to engage the locker. So I used some high strength loctite and just tightened it good.
Factory base gasket FITS PERFECTLY. Plus the copper sealant (can with brush) is good stuff, but it doesn't spread as nice as the rattle can version. I always coat my base and head gaskets in the stuff. Makes assembly easy and its a good sealer.
Discussion Starter #132
Engine installed, pwk39 carb installed with 185/55 jets; new motion pro throttle cable, clutch cable, airbox & boots installed. Has great spark and 144# comp (new top end not broken in). Need to figure out why my kill-tether isn't killing spark, but the on/off switch works as it should. Need to clean & mount the tank and she's ready to fire up. :Smoke:
I can remember when you started this. Seems like the site is dead now a days which sux. AND for some reason I don't get notifications from here anymore when someone posts to one of my subscribed threads.
Anyway keep up the good fight. It can get tough at times for me. lol
Discussion Starter #136
Holy hell, is this thing still on?? Beuhler? Beuhler??
She's running! In the end, i had to ditch the clutch cover with the extra feature to prevent an oil leak. Pulled the parts off that weird cover and SCRAPPED IT. Still don't have kill tether rewired tho, but tested run/stop switch beforehand, and installed/tensioned chain as my emergency stall-stop fail-safe.
Buttoned 'er up and she started easy. Purrs like a kitten! Sooooo nice to see & smell exhaust out of this thing. #MarathonBuild
More to come with 5 more vacation days lined up.
-Dan
Discussion Starter #138
Well the Pro Design Cool Head o-rings weren't sealing worth a damn. After it ran for 10-15sec twice, she didn't want to start. Trouble-shooted everything. Finally pulled engine and head and saw evidence of leak. Coolant does NOT like to burn. Got the stock head back on it and ready to go back into the frame.
I've been running my '88 Zilla with a stock head for years now with -0- issues.
Also putting up my other Zilla engine for sale (on CL & evilBay). Needs a clutch basket. Make me an offer!
http://toledo.craigslist.org/snw/5411215414.html
Discussion Starter #139 (Edited)
This rig is up & running! And its for sale on CL.
http://toledo.craigslist.org/snw/5428064026.html
Just installed a new stator coil and plug cap. The coil looks pretty old and has been beaten up by my flywheel tool, so bought a new factory coil (31240-19A00). And the plug cap wasn't right, so I bought the factory one (33510-2-A02). Both parts are high quality (not the crap from evilBay). Well worth the extra $.
Starts as easy as my other one now and idles nice. New owner may have to tweak the carb to their liking, but its a PWK with idle adjustment knob and mixture screw. Easy-peasy!
