1 - 8 of 8 Posts
hi again guys , i am tryin to change crank seals in a 82 rm 125 the fly wheel side is no problem,the problem is the clutch side can anyone tell me what i do or do,nt have to remove to get at seal! i see what looks like a nut and some gears on shaft but do,es the i think it is called the water pump shaft and gear have to come off too???? any tips or advise would be a great help i have never change them before thanks
Discussion Starter #2
clutch side crank seal
hi guys can anyone tell me how to change crank seal on clutch side on a 1982 rm 125???? stator side was no problem just not sure how to go about do,in the other side. any tips or info on how to do it would be great thanks..
You'll have to remove the clutch cover and the idler gear off the crankshaft, and maybe the clutch, it may be reverse thread but I'm not 100% positive on that one. Then its basically the same as the stator side.
dodge i merged the two threads you have up about this Ill take a look and see if i can find an exploded view for you....
thats why we are here
Old School but still Cool
1) Drain coolant
2) Remove Kick starter and lower brake pedal (you can lay the bike on its left side so you don't have to drain the gear oil)
3) Remove right side cover
4) Remove the entire clutch basket
5) Remove pto gear
6) Remove seal
7) reassemble
1 - 8 of 8 Posts
