1 - 6 of 6 Posts
This may be a dumb question but what is the coolant capacity for the radiator of a 1992 lt250r? Also, do you guys put in a 50/50 mixture of coolant/water? Thanks for any help.
Not sure on the capacity, but I know your supposed to dilute it 50/50 with distilled water. I'va also heard of guys running 60/40 etc.. You can also buy it already mixed.
I don't think its too hard to figure out. Fill the overflow half way (if your ride has one) remove radiator cap. fill until almost full. Run it a couple minutes then check the level. No way you'll use a whole gallon jug I would think.
When I filled mine the first time before break in I kept the cap off to keep an eye on it while I ran it for 10 minutes. I don't think I even used a half a gallon.
1985-1986 Lt250r Genius
JUST FILLED MINE YESTERDAY , not even a half gallon is more accurate
I have had my Suzuki for about a year now, radiator capacity is 1.06 liters
Purified water to antifreeze ration is
55/45 -32°C (25°F)
50/50* -37°C (-34°F)
45/55. -44°C (-48°F)
""Suzuki quad racer Lt250•1985-1992
Maintenance • Troubleshooting • repair""
1 - 6 of 6 Posts
