As the title says.
Compression testing a 2-stroke.
How do you test for compression?
What is your procedure, Kick start or push? If pushing, what gear? Cold engine?
Do you use oil in the cylinder?
Why do you compression test? For record keeping? or only when the engine runs abnormal?
What do you do with your results?
Any other information on your procedure will be greatly appreciated!
Do it after changing rings. Either cold or hot engine. Subsequent tests do the same. It's just a point of comparison to give you an idea of when to change the rings again.
