I don't really know the size difference on the carbs but I would not see why. Your biggest problem will be your throttle cable you might want to get a cable off the 250R as well.blasterwiseco said:
Good luck and let me know how it works.
I don't really know the size difference on the carbs but I would not see why. Your biggest problem will be your throttle cable you might want to get a cable off the 250R as well.blasterwiseco said:think that a carburator of 250r can be on a blaster?![]()
The carb should work as everyone has said, but you don't have to use the honda cable, as the inside may not fit your blasters throttle set up on your handle bars. If you order a new cap kit for a 34 mm carb through sudco.com (this will cost you about 15$) you can use your stock cable and throttle on your handle bars with the carb.blasterwiseco said:think that a carburator of 250r can be on a blaster?![]()
