· Registered
My 99 blaster was having trouble running so i was told to remove the tors. I removed the tors now it doesnt idle and bogs when i give it throttle. Everything on the quad is fine so do i just need the tors eliminator kit?
Also having trouble with my 04 blaster when it comes to tors. I just got my vitos big bore 240 kit installed and I broke the big flat head screw on top of my carb cap. Now it idles fine but when i give it throttle it bogs. Could that just need a tors eliminator kit too?
· PLAYTIME'S OVER BITCHES!!
if you removed the TORS cap from the carb, did you install the idle screw as well? you also need to disable the system. I would hope that you are not trying to run the stock 26mm carb on that 240BB kit. that needs at least a 35mm carb on it in my opinion.
