Ok well my blaster isn't gettin any spark to the plug......i swapped out the whole wiring harness with diff boxes an everything that wasn't the prob it still gettin nothin i even swapped the coil an the kill switch to make sure neither of them went bad. an they didn't because still no spark well i got me a stator coil that works thanx to a friend i can't put it on yet because i dont have the flywheel puller at the moment i have to wait for a friend to get home......
ANYWAYS here is my question....... ok well i have one of those lil cheap test lights that you ground somewhere an it has the lil light bulb inside it that lights up if its a hot wire ok well the blaster stator has 4 wires an i put it in each one an kicked it over the only one that lights up is the yellow wire is there supposed to be more then one hot wire??? also when i put it in there an kicked it it didn't light the light completely up it just lite it up very lil.....well actually it didn't light up at all it just glowed a dull orange.....does this mean the stator is weak an cant get the spark to the plug because its not strong enough or is there another hot wire that quit working???
Hope this all makes since to you.....just wanted to get an idea.
