1 - 1 of 1 Posts
Hi all
I've recently purchased a yz 250 2stroke and I am going to be doing the conversion to the blaster I want to gusset the frame but when checking through the frame I noticed behind the rear lower a-arm mount the bends look different to each other and all my mates blasters other than this there are no obvious signs of a bent frame and the quad drives and handles exactly as it should is there a gusset template with measurements that I could use to fab a gusset and if doesn't fit then I will know my frame is bent? I wouldn't care if I was leaving it standard because it drives fine but the fact I'm going converting I want this quad perfect from the ground up, does anyone have any thaughts on this??
Thanks in advance
1 - 1 of 1 Posts
