Hello I'm new to the forums and I need some help. My Banshee makes this rattling sound that seems to be coming from the transmission and is the exact same noise as in the video below. I first thought that it was something with the flywheel and had actually found out that I hadn't tightened the flywheel nut tight enough and that the woodruff key was split in half. I went to a Yamaha dealer and got a new key and tightened it to 60lbs. It still makes this sound but I took a closer listen and to me it seems like it's something in the bottom end. I tried rolling it back into my garage and as soon as I kicked the shifter down it shifted and the motor stalled. I started it back up in enutral and gave it a little gas when I shifted and it moved forward. When I ride around there is no power loss compared to before it started this. Any suggestions? Thank you for your time. https://www.youtube.com/watch?v=1pu8iORiLlQ
