i got a antifreeze leak some were in the old ktm, i put a new water pump seal on, changed the oil and anti freeze rode it today looked at the oil and i got strawberry yogurt.i took the right side case off to change a kick starter shaft could i have maybe torn a gasket or somthing? any input is good. thanks
well... go through it!
you've already replaced the seal, so now i'd check the water pump shaft, if it has a groove where the seal contacts it then replace it
