So I just bought a 94 blaster. Not to familar with 2 strokes this is my first one. Guy told me that it ran fine the carb clogged so he cleaned it and it clogged again. Any idea what could cause this or should I look at? I haven't had time to look at it yet.also what are some good mods to do to it? Any input would be much appreciated. Thanks
the carb could clog if the air filter is dirty so id start by cleaning that then take the carb off and clean it. Then try starting it. make sure you clean all the jets good when you take the carb apart. as far as mods go it depends on budget. you could go anywhere from an aftermarket pipe to a 240 big bore kit and a stroker crank it all depends on budget.
