1 - 6 of 6 Posts
I have used a 91 top end on a 1998 bottom end. you just have to do a little coolant line work since the 91 head has 2 coolant spouts instead of one. I would still double check your piston to head clearance, port timing, and so on. the 91 motor had a shorter stroke, my 91 and 98 cylinders were the same length and I was raising the ports anyways, but that all should be checked.
yes i do have a t4 taking up space! i bought a nice engine off ebay for it, with a very nice cylinder, since that i haven't touched it! i just bought a 93 kx250 and it needs a cylinder. so maybe i can use any kx cylinder on it?!! probably even put the t4 jug on it! lol
I have a 93 kx need a cylinder can you swap for another year did you do it ? Did it work ?
1 - 6 of 6 Posts
