I just picked up an 86 today and I have a couple 88 parts quads. I want to swap the swingarm. What do I need to do? Is it pure bolt on? Can I just swap the whole rear axle suspension assembly? Thanks
From what I understand as long as you have all the parts from both you can make it work and it is just bolt on. If you do it please write down which parts you used from which swingarm/shock so we will all have that information the next time someone asks about it.
Forced into starting this because I broke my swingarm/carrier trying to tighten the chain. Everything is direct swap no problem except the chain needs to be longer
