Nope wish they still made it I would have bought one over my F350 Diesel anyday.
huh I thought they had it in a truck, they had the motor on Trucks one morning but the motor was out of the chassis so I guess I just figured it was to a Truck, All set with the bus my F-350 is pretty damn close to the size of a bus. A cement truck would be nice. Make it easy to get rid of the bodies370banshee said:those came in city buses and cement trucks jason......
I'm having a problem with My 1978 Detroit 671 inline diesel. It has been blowing white smoke and I discovered the crossover tubes were loose letting diesel down into the oil in the crankcase so I got those all tight and changed the oil and put it all back together but now there is oil blowing out a little 3/8 diameter tube coming off the passenger side of the block just above the drain pan towards the clutch end of the engine? Like if I rev the engine to see if it's going to smoke like it was before and the RPMs are up to 2200 I look under the truck and a steady little stream of oil is shooting out of this little metal 3/8 tube that points down like it's a little baby breather tube? If anything I have just enough oil in it right now it's all the way at the bottom of the stick until I can make sure diesel isn't still getting into the oil. It looks like the engine has a new head everything is immaculate I haven't run the rack yet but I did check a few things on it and everything seemed to be working very well. But I still have some white smoke at idle and a lot of white smoke at 2,200 RPM. Does anybody have an explanation of this little baby breather tube and the white smoke? Is it possible for injectors to overfeed even if the little racks are all working freely and everything seems good in the injectors are basically new?well kane a detroit diesel is in a way a combination of a 2 and 4 stroke
it has valves for the exhaust but the air is delivered through a port on the side of the cylinder
so when the piston comes down it uncovers a port on the sid eof the sleeve and air is forced into the hole
and a standard exhaust valve lets the spent gas out
This is a picture of the little draft tubeI'm having a problem with My 1978 Detroit 671 inline diesel. It has been blowing white smoke and I discovered the crossover tubes were loose letting diesel down into the oil in the crankcase so I got those all tight and changed the oil and put it all back together but now there is oil blowing out a little 3/8 diameter tube coming off the passenger side of the block just above the drain pan towards the clutch end of the engine? Like if I rev the engine to see if it's going to smoke like it was before and the RPMs are up to 2200 I look under the truck and a steady little stream of oil is shooting out of this little metal 3/8 tube that points down like it's a little baby breather tube? If anything I have just enough oil in it right now it's all the way at the bottom of the stick until I can make sure diesel isn't still getting into the oil. It looks like the engine has a new head everything is immaculate I haven't run the rack yet but I did check a few things on it and everything seemed to be working very well. But I still have some white smoke at idle and a lot of white smoke at 2,200 RPM. Does anybody have an explanation of this little baby breather tube and the white smoke? Is it possible for injectors to overfeed even if the little racks are all working freely and everything seems good in the injectors are basically new?
