I was thinking of purchasing an '87 CR250, looks clean, needs piston. Just before I was about to pounce on it, the guy told me that he had replaced the crank with one out of an '82 he thought. He said they looked identical.
I don't want to get into a bike that may have a big problem -- are the cranks compatible? Is this a deal-breaker, do I have a reason to be concerned?
i cant find a site that has it. but look to see if the model changed between 82-89. if it didnt youll be good.
Old School but still Cool
The cranks did have some changes on them. The crankshaft for the 87 was much improved over the older 82 in that it was a full disc crank and the 82 was the cut disc crank which was supposed to be better because it weighed less but it was not as strong. I wouldn't say it is a deal breaker but you would be smart to negotiate some and if you buy it get the correct and better crankshaft.
