1 - 4 of 4 Posts
· Registered
im going to be rebuilding my front forks in the next 2 weeks and was wondering if anyone knows the procedure for servicing the closed cartridge? how many cc's of oil? I have seen at a couple of ktm sites that there is a tool that looks like a bicycle air pump that is for the 07-08 forks. so does the cartridge take air or oil? and if anyone knows the amount of oil required for the outer chamber that would be good too. thanks in advance
· Registered
There is a bladder on the top of the cartridge unscrew it and fill the cartride with 195ml of 5w fork oil. You should fill the bladder with 15-20psi with nitrogen (that's what I use anyways) fill the bladder after it's screwed back into the cartridge or it's a bugger to get it to seal. Sorry but I can't remember what the outer fork oil level is, my spec book is at work. If you go to www.racetech.com it might have that oil level there
1 - 4 of 4 Posts
