I have an '02 blaster. 100% stock. When it sits there is not leak, but after i ride and let it sit it begins to drip red fluid towards the front bottom part of the engine. The trans fluid is ok and nothing is cracked. What could this be?
Is the leak coming from the exhaust flange?
If it is, your crank seal on the clutch assembly is going bad , causing the transmission fluid to get sucked into the cylinder and out through the exhaust pirt.
I honestly cant find the leak. But after i ride it, the leak seems to be worse. Im thinking about just buying a complete gasket and seal kit and redo all of them. Might do a top end rebuild too, there is a ticking noise when its running. Its 12 years old, so its just time to freshen up the engine!
